reprocessing TPE and PP insert molded products
hi,
I am currently insert moulding a handle wherein TPE is moulded over PP . I want to know is whether we can reprocess the scrap thus generated in the process? Also is it possible to remove TPE coating from PP product again for the purpose of recycling the products separately. If yes then how can I do this else how can this be reprocessed.
it would be good if you could guide me through this issue.
aseem jaggia
aseem jaggia
RE: reprocessing TPE and PP insert molded products
Dr. Chris DeArmitt
Plastics consultant to the Fortune 500: www.phantomplastics.com
Webinars on plastics, fillers & impact modification: www.plastictraining.com
Otherwise, it's better to avoid making scrap in the first place.
Mike Halloran
Pembroke Pines, FL, USA
I came across an additive called Polymag which you can add at 1% to make either the TPE or PP magnetic. Ten you can crush it all up and seperate the magnetic regrind from the non magnetic regrind. I have'nt had the chance to see if it really works and to see if it is cost effective.
If you do go ahead with this please do let me know how it turns out. I'm not sure if it is food contact safe or if you can produce any color you wish with this additive. Eriez I think is the company.
Another idea I was playing around was if I can add CaCO3/Filler to the TPE to increase its density and there by seperate the crush material with water. I haven't tested this idea as yet.
Chris DeArmitt PhD
President - Phantom Plastics LLC
Consulting, ideas and training on plastic materials
Chris DeArmitt PhD
