Manhole Size for Parallel Pipe
I have a double run of 36" RCP for storm drainage and need an interim junction. My supervisor wants me to use a circular manhole, rather than a rectangular junction box thinking it would be more economical (not sure about that, but I guess we'll see). Assuming this junction only has two parallel 36" RCP's coming in and going out (i.e., no other pipe penetrations), what is the minimum diameter manhole required? Design references or resources would be appreciated. Also, what is the minimum gap required between the parallel 36" pipes...I was assuming 12-18" in order to properly compact. I suppose I could separate the lines a little more and have 2 manholes side by side, but I'm not sure if that would be economical. And before you may ask...no, I can't change the two 36" RCP's into a larger single pipe (round, arch, elliptical, etc).
The following link was pretty close to having a solution, but not quite there: http://www.dot.state.fl.us/rddesign/DS/06/IDx/200....
Thanks in advance!
Thanks in advance!
RE: Manhole Size for Parallel Pipe
But like the others suggested, go with the dual junctions if you can.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
