B31.3 "Fluid Fields" on Line list
Hello all,
Why is the fluid category (D, M, N, etc per B31.3) on some Line Lists?
Why is the fluid phase on some Line List?
Why is the fluid density on some Line List?
When are these fields used during the design and construction? Does anyone know?
RE: B31.3 "Fluid Fields" on Line list
Fluid phase can affect supports and loading of the pipe if two phase flow is present in some lines, but not others
Fluid density can affect supports, especially if greater than water weight (assumed for hydrotest) or subject to sudden changes.
Kind of a generic question so I'm afraid it was a generic answer. Is there something specific you need to know or curiosity?
There is no such thing as a 'Standard format' or any 'Code specific format' for the document that lists all the pipe line on a project.
There are however at least two names for this document:
(1) Line List (LL)
(2) Line Designation Table. (LDT)
As for what column titles or Data listing, it is simply a Client and Project specific basis.
prognosis: Lead or Lag
It has been two months since we last heard from you.
Any update to share with us?
