Requirement For Clean Room, Class 10,000
This is the first time I design for clean room, class 10,000. I could not find any design guideline, hopefully, some Clean room expert can help me out:
1. How many air change should I apply for this clean room class 10,000 ?
2. Can I use the return air (or partial return air) or have to be 100% outside air ?
3. If it is 100% outside air, can I use heat wheel to recoup some lost load ?
If there are some special requirement for this class, please guide me .
Thanks in advance
HT
Thanks in advance
HT
RE: Requirement For Clean Room, Class 10,000
2. You can use recirculation.
3. Typically you will use a glycol loop from the exhaust stream for enenrgy recovery.
ISPE has a Good Practice Guide on HVAC that will explain more in depth.
knowledge is power
