Part Description abbreviation clarification
New here, so might not be in the right section, but I need clarification on a description and was looking to you guys since I can probably get a faster response.
the part is a hose/pipeline that carries either steam or water but that's all I know. Can I get some clarification?
ASSY, TFLX,.50,46,F.JIC X .50 MPT
I have multiple parts like this with the only number changing is the '46'. it changes to 39, 33, 32, 86, 79, 14, and 60.
RE: Part Description abbreviation clarification
Cheers,
John
"IF" it is MPT then you have to be very, very careful to verify that they are Metric Pipe Threads instead of National Pipe Threads!!! One will not fit the former.
Thanks for the info.
Cheers,
John
