Pattern Feature - Trim Body
RE: Pattern Feature - Trim Body
In a case like this, simply use 'Pattern Face' instead, as I did with the attached example. If you stop for a moment and think about it, in this particular situation there is absolutely nothing that 'Pattern Feature' could have provided you that 'Pattern Face' isn't. Pattern Feature is useful IF you really need to maintain the fact that each instance is a 'feature' that you could edit as if it were still a standalone feature. If all you want it to be able to edit the original feature and have all of the instance update to match it, then 'Pattern Face' if the way to go, for several reasons. First off, the model will have a simpler Feature Tree, it will update faster and it will take up less space on Disk. Sounds like a winner to me.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John
NX 6.0.5.3, NX 9.0.2.5
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
