Self cementing properties of calcrete
How can i evaluate by testing the self cementing properties of calcrete gravel?
Self cementing properties of calcreteSelf cementing properties of calcrete(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Self cementing properties of calcrete
Compact the material into a CBR mold with its moisture content at around 10 to 11 percent by weight. Soak the material,in the mold, for at least 24 hours, then carefully extract from the mold as a cylindrical specimen and allow to dry. Run an unconfined compressive strength test on the material to determine its compressive strength. Compare to similar, non-cementing materials.
The second method is similar except you will simply place the material into a 6" diameter by 12" tall compressive strength test mold and moderately compact it in 3 lifts. We the material and allow to soak for at least 24 hours. Pour off all water, allow to air dry and then test in unconfined compression. Compare to other similar, but non-cementing materials.
If in either case your unconfined compressive strength exceeds about 200 psi, you are getting some significant cementation.
Good luck.
