Right Click Menu File Export PRT to PDF
Follows attached customization to export a PDF file from PRT.
This customization create a context menu to Windows Explorer allowing export pdf.
Is inside the following files:
INSTALL.BAT
PRT_to_PDF.vb
Export_PDF_Menu.reg
Export_PDF.bat
Known issues:
When you select a lot of files to convert maybe the pdf created are incorrect
if anyone can help with this issue thankful
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
