Comparing two products with the same part number
Morning all... In my line, we deal with a lot of upissued parts from auto manufacturers, and we have to overlay the old and new revisions in order to ascertain the changes. Normally the part number won't change- just the revision.
Now, when I do this, I normally do new product, then insert new component(s). Problem is, with Catia (V5R18) I can only ever have one model with the same part number open at once. If I add them one at a time the first one opens, then I add the second and "oops, you don't want to look at that... Let me open the first file, again. Then you don't have to worry about re-quoting anything, since you won't see any changes- you're welcome,user" Frustrating!
I normally get around it by saving one or both as a STP or IGS file on my desktop, then doing an overlay- but surely there's a better way than that?
Thanks in advance.... Whether you lot know how to do it properly, or just agree with me that it's a right old faff
RE: Comparing two products with the same part number
see this link for a quick video
http://www.youtube.com/watch?v=kb_iyLEO18Y
MTM
CSWA Certified
ATC Certified
CAD Blog
http://mtm-cadtutorials.blogspot.com/
Profile
http://www.linkedin.com/in/mtmcad
When using Teamcenter, there is a Load for Compare in CATIA V5 option, so you can have 2 versions open at once.
If you are not using TCe, you can use the Tools | Generate a CATPart from Product command, which will create a dumb part.
Then you can create a Product to compare them.
toyayo- I think this is probably the way to go at the moment, thank you very much!
Cheers all
Si
I've done something like this for few hundreds of harnesses in batch mode....without DMU licenses you can save each product as a 3dxml file, each one with their separate colors, then insert those files in a product to be compared.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
