Maximum allowable stress values for bolting in ASME IID
Hi There,
How do I get the maximum allowable stress values for:
1. A320 L7M bolting material with diameter larger than 64mm?
2. A193 B8M CL1B bolting material?
Both of the bolting material mentioned above are not available in ASME IID, but it is acceptable to be use as per ASME Boiler & pressure Vessel Code VIII, Table UHA-23 & Table UCS-23.
Appreciate your help on this. Thank you in advance.
Celina
