Component tis non-geometric after adding component in NX-6
Sometimes I face this issue when adding the component to the assembly nothing is showing up in the preview window. I checked all the layers setting and reference set of the component being to be added everything is fine, still the issue is same. I added the component absolute origin it was blank in assembly navigator the component is like in hidden shape not a solid one. In component properties (using RMB on component) Checked-off the “Component is Non-Geometric” than the component is visible to position.
Does anyone know how to remove “Component is Non-Geometric” before adding to the assembly?
RE: Component tis non-geometric after adding component in NX-6
thread561-309958: All New Parts Show Up As Non-Geometric Components in Assy Navigator
thread561-360113: NX85 - Add Component is by default Non-Geometric ?
www.nxjournaling.com
I have changed DB_PART_UNIT type from IN to each and it worked well issue is resolved.
