Steel insert in enclosed Aluminium section
Hi there
I need to calculate the maximum bending moment for an aluminium section which has two steel flat bars fixed inside the section. I know how to calculate the Mu for the aluminium and steel section separately. I was wondering if it possible to just superimpose the two Mu's onto each other to get a rough reading?
(I'm a student working at a Aluminium company. The companies just wants to see if its feasible before sending it to a certified engineer)
Thanks in advance for your replies.
RE: Steel insert in enclosed Aluminium section
It seems a waste adding steel to the inside of a section, ideally you would want it on the outside of the section, anyway take a look at this site:-
http://hardened-steel-reinforce-aluminum-profile.c...
It depends on how they are fastened to each other but most likely they will take load according to their stiffness. Unless I'm misunderstanding the question.
EIT
www.HowToEngineer.com
@desertfox, I agree that adding steel to the inside is a waste. Thanks for the link!
To get a rough estimate, I multiplied the Inertia of the steel section by 3 (with E of steel being 3 times larger then that of aluminium) and just calculated the deflection based on simple beam formula (using E as 70000). It came out that the section would deflect far to much.
Could anyone vouch for using this method?
Where did you come up with 70,000 for "E"?
Mike McCann
MMC Engineering
Your method is incorrect I feel see this example here under composite beam:-
http://www.roymech.co.uk/Useful_Tables/Beams/Beam_...
The members are not designed to act as a composite beam. The load is distrubuted to each member based on relative stiffnesses. So, alrighty93 is correct in transforming the aluminum shape to steel by multiplying by Esteel/Ealuminum, which is approximately 3.
The connection is simply made by screwing through the aluminum member to the steel member. Enough screws need to be provided to transfer the appropriate amount of load into the steel shape.
Can you provide a sketch like Robert Hale requested earlier, it might clarify a few things, the reason I believed your method is incorrect is because you've stated "I multiplied the Inertia of the steel section by 3".
Normally the width dimension of the aluminium section would be divided by the ratio of the elastic moduli to obtain the equivalent steel section, in this case 3, or the steel section multiplied by 3 for the Aluminium section equivalent.Then from the whichever equivalent section you choose, you go on to calculate the moment of inertia for the appropriate section, I haven't seen a situation where you simply multiply the inertia of one section by the ratio of the elastic moduli but thinking about it I suppose it is possible.
