Vortex Breaker design
Why do some liquid vortex breakers have caps on top of the usual cross type design? what is the advantage?
thanks for any help
thanks for any help
RE: Vortex Breaker design
prex
http://www.xcalcs.com
Online tools for structural design
prex
do you know of any available literature which details the pros & cons of different designs of vortex breakers? or of any research available?
The first is a crossed plate inserted into the throat of the outlet pipe in a tank; the length of which is roughly 1.5 times the diameter. This works best if the outlet pipe is on the side of a tank. A design guide is "ANSI/HI 1.1-1.5-1994 Centrifugal pumps for Nomenclature, definitions, applications and Operation." No design dimensions are given, pointing out the "seat-of-the-pants" origin of this device.
Alternative:
If the outlet from a tank is on the bottom, a baffle plate can be placed over the mouth of the pipe. The rough dimensions are as follows: The outlet pipe diameter is "d" (known), the baffle plate diameter is "4d", and it is placed a distance "d/2" from the outlet pipe. Installing the baffle plate above the pipe opening will simulate a larger intake area, thereby reducing the vortex and air entrainment.
The crossed plate will work okay for a bottom-mounted outlet pipe too. A crossed plate with a cap sounds like a home-brewed solution to vortex breaking.
