PVRV for Fiberglass Acid Tank
Hi guys. What would you suggest for pressure-vacuum protection (a PVRV) for a tank that stores 35.2% hydrochloric acid? The tank is 20,000 gallon capacity. It breathes to atmosphere via an acid vapor scrubber. A PVRV must be fitted to protect the tank in case the scrubber packing plugs up. I am looking for something like a Varec 220 or 221 but those aren't available in Hastelloy. Thanks!!!
RE: PVRV for Fiberglass Acid Tank
