"te" Clarification
"te" Clarification
"te" Clarification
I tried looking around for an official code interpretation, but couldnt find anything.
We have a customer seeking an integrally reinforced nozzle similar to ASME Section VIII-1, Fig. UG-40 (e-1), is it the intent of the code to limit the credit of "A5" available reinforcement to the height of “te” even when there is additional excess integral metal within the reinforcement zone? If so, does anyone know the reasoning behind this?
RE: "te" Clarification
It can be to compensate for loadings.
Fig.UG-40(e) is clear to me: if the thickened portion is shorter that 2.5tx use (e-1) and the limit of reinforcement is the smaller of 2.5t and te+2.5tn; otherwise use (e-2). Then all the metal available within the limits can be used for reinforcement, it is not the intent of the dotted lines in (e-1) to limit the available metal.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
