"Tie interaction" view in Abaqus/CAE 6.10
Hello everybody,
When using "tie constraint" between two parts which are not stuck (there is a 5 mm gap between both), I specify a "position tolerance" of 6 mm. No problem with that, my calculation works fine.
My question is : Is it possible to check visually which node is connected to which one, once the mesh is done ? It could be useful to check if my "position tolerance" value is relevant or not.
Thank you in advance for your help,
Best regards,
Belorado.
Best regards,
Belorado.
