Consolidated Undrained Triaxial Test Back Pressure Problem
I am using an ELE Digital Tritest 50 System (which is unfamiliar to me) to test a CU TXL.
So far I seem unable to get past the consolidation stage, as overnight the back pressure creeps up to just below the cell pressure.
I have ruled out the bladder as a cause for this.
Any ideas?
RE: Consolidated Undrained Triaxial Test Back Pressure Problem
I assumed you figured this out - but it sounds like you have a leak.
