Torsion Springs
Torsion Springs
Torsion Springs
Is the formula to derive the k factor for a torsion spring the same as a compression and tension spring?
k=6Gd/8nD^3
where G is the modulus of rigidity, d is the wire diameter, n is the number of coils and D is (OD minus wire diamter).
