question about debuging in NX
I found two posts here:
http://www.eng-tips.com/viewthread.cfm?qid=290183
http://www.eng-tips.com/viewthread.cfm?qid=364048
Quotes:
1. Start NX
2. Start VS with the project you want to debug
3. Create one or more break points in the project
4. In VS choose Debug->Attach to Process...
5. Choose ugraf.exe from the list of processes.
6. In NX start running your project in whatever way you want (eg File->Execute->NX Open)
(after i follow step 6, NX asks for dll file, which dll file to pick?
http://files.engineering.com/getfile.aspx?folder=1...
7. When one of the breakpoints gets reached NX will hang while you step through the code.
8. When you want to stop debugging, in VS choose Debug->Detach All
Quotes:
1. Start NX
