Show Interference in View sectioning is not activated
Hi All,
NX8.5..
I turn on the Show Interference while doing view sectioning.. I click on on the view sectioning command. I have the remember dialog memory checked on for the role.
It stays active till have the session open.. If I close the session and re-open a new session, then I have to check mark the option for show interference again..
Have anyone else seen this? Seems like a bug..
NX8.5..
RE: Show Interference in View sectioning is not activated
I have just tsted on NX8.5.3.3.mp3 version and it Works. I have selected 'Show Interference' (View/Section/New Section, Cap settings group).
Then, I have created a new file. Setting 'Show Interference' was turned on.
I have then closed all files and again created a new file. Again, there was no problem with 'Show Interference'.
Then, I have closed NX and open NX again. And the option 'Show Interference' was still turned on.
I have done this test first with System Role. Then, I have created my own role with Save Dialog Memory on and still, there was no problem.
www.nxjournaling.com
I have NX8.5.3.3 MP1 ..
