Displaying Formulas and Values
Hi Guys,
I have MathCad 8. I need to show my formulas and their values e.g. (M = wL^2/8 = 100x10^2/8 = 1250).
I cannot get MathCad to show the values without displaying the its' assignment.
Frantic
Frantic
RE: Displaying Formulas and Values
I would suggest you go to the mathcad forum and attach your file, those guys are very helpful.
The best I can think of is to write
M : w*L^2/8
100*10^2/8 =
Which does what you want, but it is a pain.
I can't imagine there is much value in showing the intermediate step very often, one of the things MathCad normally gets right is assigning values to variables.
Cheers
Greg Locock
Frequently, in engineering, as the values change you need to verify what they are rather than relying only on the result of the equation.
Frantic
w:100
L:10
M:w*L^2/8
M=
will show you exactly what inputs you used, and the equation, and the result. Isn't that good enough?
Cheers
Greg Locock
http://collab.mathsoft.com/read?22534,12
TTFN
As usual there are depths of detail in MathCad that are far beyond my useage.
Cheers
Greg Locock
W:100, L:10 (or any other value)
M:W*L^2/8
Symbolically evalue M --> or using the keys [Ctl] + [.]
The result should be M--> 100. 10 SQRT(4)
Good luck
M:W*L^2/8 would look like:
M=100*10*2/8
as a means of verifying the correctness of the calculation process instead of just the final answer
TTFN
There are plenty of workarounds, such as displaying the individual values AFTER the calculation.
TTFN
M:45
L:85
w:M*L^2/8
w[CTRL]+[SHIFT]+[.]=
THIS WILL GIVE: W-->45*85^1/4=136.637
ZMEI
