Rapid dimension - tolerance limits and fit
Hey,
my favorite operation - Rapid dimension.
I want insert dimension with tolerance H7. I selected dimension, selected points, wait for key, select key, select H7(limits and tolerance), deselect key and placement dimension.
After I want insert dimension with tolerance g6. That same: select dimension, select points, wait for key, select key, select H7 and...
Select Style Window, select tolerance, select Shaft, close Style window and back to dimension window, deselect key and placement dimension.
I think - small dimension window should have switch to select "Hole", "Shaft" or "Fit".
Maybe there is another method for change this tolerance.
Best regards
Michał Nowak
If there is something stupid and it works, it's not stupid.
Best regards
Michał Nowak
RE: Rapid dimension - tolerance limits and fit
thanks.
