Column strip bottom bars (Two Way Slab)
13.3.8.5 — All bottom bars or wires within the
column strip, in each direction, shall be continuous or
spliced with Class B tension lap splices or with
mechanical or welded splices satisfying 12.14.3
Refer to Figure 13.3.8 of ACI 318.
I don't quite understand the intent of this requirement. Assume I have a slab with #4@12" continuous bottom mat, spliced at support and require 4#5 bars in the mid-span of a longer span. Is the code saying that the 4#5 bars column strip bars that I added for strength requirement on a longer span should now be continuous across the entire length of the slab?
Doesn't make sense to me.
RE: Column strip bottom bars (Two Way Slab)
I think that provision was added in response to the Oklahoma City bombing. At least that's what my very faulty memory suggests. I have an 89 version of the code handy at it doesn't have it in there so the timing seems roughly correct for that to be the case. I do remember that in the aftermath the discussion related to stress reversals from the initial upward blast, breaking the beam where there was no "positive" (no negative) reinforcement and then, once the initial upward impulse ended, the downward force acted on broken beams that then had insufficient shear capacity. Or something to that effect.
Anyway, my interpretation of code is that yes, in your situation those 4-#5 bars would need to be continuous. (Sorry.)
Is there any way to edit posts?
I do not continue the add bars beyond the required spans and I've seen the typical details of other firms that also do not. Add bars are in the required span only. I'm not sure if that meets the letter of the code but I think it meets the spirit. Seems like the intent is to provide for some catenary action in the event of a loss or partial loss of support. In that case there is no argument for continuing the bars across the entire building - at the most I guess you could argue for continuing them to the next adjacent column and developing there, although I don't see anyone even doing that.
If you simply extend the bottom bars a class B length past the ends of the opposite span bottom bars - or for a bit more conservatism - extend them past the face of support so you have at least developed your bottom bars past the column face by 1.3 x ld.
Or to put it another way, bottom steel should be continuous over the supports, not cut off in regions of negative moment as was previously allowed. That does not mean that every bar that is required must be continuously developed from one side of the building to the other. Were that the case there would be no need to design more than one bay in any given floor level.
I'm sure the above is poorly written and I can seem to word it clearly. But, I think the point is that there be bottom steel over the columns, not that any bottom steel that is required run from one side of the building to the other.
However, there may be additional bars that are only added per span, which don't extend through the building width.
It appears that the code doesn't permit it which is where the code is poorly written. The commentary for this section talks about progressive collapse resistance, but apart from the minimum 2 bars through the column core, it does not say if only a minimum bottom steel needs to be continuous in the column strip.
Although I was not familiar with this requirement, not having used ACI318 for slab design in some years, I think the intent is quite clear.
My interpretation is that wherever you have columns supporting a slab, all the bottom reinforcement in the column strips must extend continuously to the columns either side, with splices permitted in accordance with the Figure. It does leave the question of, in the case of unequal reinforcement requirements, which is to control, but I think the lesser amount would be acceptable in lieu of better definition.
The two bars through the column is a separate requirement, for punching shear.
I would hope ACI would clarify the requirement in a better way.
