Bearing Load Calculations
Hello. First time using this so apologies if I put this in the wrong spot but this looks like the right forum.
I am looking to select new bearings for a pump we mfg. I have the weight of the pistons, weight of the crankshaft, the distances from bearing to each piston. The thing to note is the radial loads are not all in the same direction. This would just be a summation of vectors then; correct? Anything else I am missing?
RE: Bearing Load Calculations
The bearings will also care very much about their rotating speed.
Don't forget the 'belt pull' if the crank is driven by a belt, or the gear separation force if it driven by gears.
Even if the crank has only one throw, there may be harmonic oscillations traveling along it.
Can the pump be backdriven by the pumped fluid if the motor loses power? That's a failure scenario that you'd want to mitigate.
How accurately can you make all the crank bearings align with each other? Can you make the crankcase straight and rigid enough to maintain that alignment, or is it flexible enough to need shimming to get it straight? What if the skid underneath the crankcase is warped?
I don't care about the answers to all those questions, but you should.
Mike Halloran
Pembroke Pines, FL, USA
