Does anyone know how to convert .dwg files to .gif. I am using autocad 2002 and am trying to make my files move such as gears or engines (cut away to show the internal parts. Is there a converter that will convert .dwg to .gif?? Or maybe I don't necessesarily need .Gif but can use something like .Jpg ??? Thanks, Chris
RE: .dwg files to .gif
The SAVEIMG and EXPORT commands can produce some graphical formats for your drawing.
Farzad
In addition to the last post, just use the Add a printer wizard and create a MY COMPUTER - HEIDI driver printer config. When the Manufacturer list box is shown, select the raster file format and pick the format you want. Remember to plot to file and you should be good to go. Good luck.
BU
