Problem import NASTRAN input file created by Patran 2007 with Patran 2013 (# Error APP INTERFACES )
Hello
I have just installed Patran and I try to import a NASTRAN input file created by Patran 2007 and I have the following Error:
$# Error reported in application APP INTERFACES by application FILE
$# Fatal errors encountered trying to read input file. The import process was aborted.
Could anybody help to solve this error
Thank you
Best regard
Marvin
Thank you
Best regard
Marvin
RE: Problem import NASTRAN input file created by Patran 2007 with Patran 2013 (# Error APP INTERFACES )
You can find it attached
Thank you
The model I could open with no problems
I will check the nastran license
Thank you very much
Best regards
Only one more question, where can i get this patch; when I downloaded I only find the lecense generator.
Thank you
Best regards
Marvin
