Average surface temperature in Ansys Mechanical
I'm new to Ansys and am doing some very simple heat conduction modeling in Ansys Mechanical. I wanted to see if there is a simple way to find the average temperature of a surface after you have the results.
RE: Average surface temperature in Ansys Mechanical
HI Kbagnall,
Assuming this is query is still active and you are using Workbench environment.
You could use the 'worksheet' button displayed once you click 'solution' in the model tree on left. And select user defined results and select nodal temperature 'TEMP'.
Thanks.
