Linked body: replacement assistant, name based does not work
In the company I work, we use a lot of freeform and use the wave linker all the time.
When a model is final we always break the link of all linked bodies in the model.
If we have to make a revision of the part, then we have to repair the broken links is necessary. The replacement assistant does a great job when we use the matching algorithm "geometric" but it can take up to 30min to find all the matches.
I think the name based algorithm should be much faster, but I can't get it to work. It always says 0 matches found.
Even GTAC doesn't have an answer.
Does anyone knows how the name based works?
thanks,
Fred
thanks,
Fred
