12 pulse rectfier
12 pulse rectfier
12 pulse rectfier
Please verify,
A 3 phase center tapped secondary transformer configured as a star rectifier will have a 0 degree phase shift with a wye primary.
But a 3 phase center tapped secondary transformer configured as a star rectifier will have a 30 degree phase shift with a delta primary.
Paralleling these two star rectified outputs through an interphase reactor will produce a 12 pulse output.
Thanks in advance....
RE: 12 pulse rectfier
Confirmed. But you need to have same voltage on both secondaries to mak it work.
Gunnar Englund
www.gke.org
