High Volume Chemical Pump
Hey guys,
I'm currently a ME intern and am working on a project that requires a high volume chemical resistant pump.
I'm developing an automated chemical delivery system for metal finishing. The chemicals are highly caustic and I can't seem to find a pump to move the volume of fluid I need.
The current manual dispensing is a safety concern so we're looking to automate. Doing the math the current method is capable of 27.1-49.4 gph if they run back and forth non stop.
The pump I'm looking would need to be able to pump about 1 gal of fluid in about 15 seconds. The most caustic material we're dealing with contains 60% sulfuric acid.
Can anyone recommend any pump manufactures that can meet these needs.
Thanks guys!
RE: High Volume Chemical Pump
1 gal / 15 seconds = 4 gallons per minute, this is not a high volume on any scale that I'm familiar with. I'd imagine you can find off the shelf composite (plastic) pumps to do this.
I think I found some actually, search McMaster.com for Extended-Life "Sealless Plastic Centrifugal Pumps. "
First up, learning to use the Internet mightn't hurt. Google chemical process pumps would be a good start.
