Sulphuric acid bulk storage tank vent
I wish to have some detail of the design of the vent on large concentrated sulphuric acid storage tanks; and whether and how it helps in avoiding the absorption of moisture from the atmosphere.
RE: Sulphuric acid bulk storage tank vent
Does this help you
Adsorbent suppliers could help you specify dessicant for a vent; details may depend upon your local atmosphere (temperature, relative humidity).
Good luck.
Thanks again
No, you should be concerned about generation of dilute acid from improper venting....
Corrosion can and will occur if a dilute surface layer of sulfuric acid forms within a carbon steel tank.
See page 12 of:
www.genchemcorp.com/pdf/tsr5078.pdf
GENCHEM has a long history of handling H2SO4
MJC
