Expression Formula frustration
Ok, to some this is going to seem simple but its driving me nuts... (Yeah it was a short drive)
I am trying to simply do this in NX 7.5.
if diameter = ....then.... sta =
16.0 - 23.99 ....then.... 0.50
24.0 - 29.99 ....then.... 0.75
30.0 - 35.99 ....then.... 1.00
36.0 - 41.99 ....then.... 1.50
42.0 - 47.99 ....then.... 2.00
48.0 - 53.99 ....then.... 2.50
54.0 - 61.99 ....then.... 3.75
Help Help me Ronda!! winky smile
RE: Expression Formula frustration
For the formula on your sta expression, in the extended text entry you should be able to copy/paste this and it should work (tested on 8.0.3.4 - assuming it will work on 7.5). Modify the zeros to whatever you want the value to be if it doesn't fall in any of those ranges.
If ( diameter<16 )
Then ( 0 )
Else If ( diameter<24 )
Then ( .5 )
Else If ( diameter<30 )
Then ( .75 )
Else If ( diameter<36 )
Then ( 1 )
Else If ( diameter<42 )
Then ( 1.5 )
Else If ( diameter<48 )
Then ( 2 )
Else If ( diameter<54 )
Then ( 2.5 )
Else If ( diameter<62 )
Then ( 3.75 )
Else ( 0 )
Daniel Sikes
Design Engineer
Young Touchstone
NX 8.0.3.4
Ahh ok. I had something similar but kept getting 0 (else). I added "in" after the diameter value because it is inches. Now its working! Thanks! I just needed someone to help me know I wasn't losing my mind.
If you wish to mix units in a single expression, when you enter the number that you wish to be evaluated different than the units for that expression, just include the units inside of closed brackets. For example, lets say I'm creating an expression that is being defined in millimeters but I've got a value that the system needs to consider it as being in inches, such as 'X = 26 + 17[in]', which would come-out as 457.8 millimeters (26 + 17*25.4). And it isn't limited to just mixing Imperial and Metric units. You could also do something like this, 'Y = 12[ft] + 14[mi]', where the result is 887,184 inches.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Awesome thanks John!
Do you know if I can add this value to a dimension's actual tolerance instead of using a note to display the value?
While you can replace the basic value of a dimension with a link to an expression or attribute, you can't access the tolerance values to do the same thing. About the closet that you can come is if rather than using bilateral tolerance call-outs, you used a one or two line 'Limit' type tolerance scheme. The only other approach would be create just a basic dimension and using appended text create the bilateral tolerances. That way you could now control the values displayed using expressions or attributes. Of course, you'd need to know how to properly format a note so that it looked like a bilateral tolerance, which is what's shown below:
In this case the text string in the editor, which you would enter as 'Appended Text', would be: <T+<X1.3@tol>!-0.005> where 'tol' is the expression whose value is .002 and where the '1.3' is controlling the formatting of the numerical value, with the '1' indicating a leading zero (an 0 would have excluded the leading zero) and the '3' is controlling the number of decimal places.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I need the tolerances of my PMI Dimensions to flow properly to other tools such as the VSA Teamcenter Tolerance stackup Analysis tool, so I am assuming appended text will not do the trick. Also, it is a table driven part with certain versions requiring different tolerances. So there is no sophisticated way to link a tolerance to an expression in my table and have this update accordingly for each part?
Daniel Flora
Are you talking about a tolerance value, as ENTERED on a Drwaing, 'driving' the table? Or are you asking for changes going in the other direction, that is changing a value in a table updating the tolerance value as seen on the Drawing?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am hoping to put tolerance values in the part family spreadsheet so that I can generate multiple models with varying tolerances and those tolerances will properly update on the model. I am not concerned with the drawing at this time, just the model. I am incorporating tolerances into the PMI Dimension objects.
Whether it's on a Drawing or using PMI, the issues are exactly the same since the code is basically the same, only the manner in which the items are presented is different.
Note that there is nothing preventing you from creating a series of expressions in your Part Family model which represents that various tolerance values that you would like to eventually use in either a PMI or Drawing Dimension 'appended text' or inclustion in some table, just that you'd have to create the so-called 'tolerance' block using the techniques described earlier in this thread.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The issue is a so-called "tolerance" that exists as an appended note to the dimension is not going to be recognized as a parameterized tolerance value and used for evaluation in tolerance analysis tools.
That is true. If that is what's needed than I guess, without resorting to using NX Open tools, such as Knowledge Fusion, there is no way to link an actual tolerance value, as shown in a Dimension, to the value of an Expression.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
