Potable Water Storage Tank Vent Sizing
Dear all,
I have a problem calculating vent sizing for potable water storage tank (concrete), the tank is designed to operate at atmospheric pressure. The tank is 10.5 m Width , 14.5m Length and 4.5m height. Maximum level of water is 3.5m.
Maximum flow rate @ inlet = 350 US GPM and Maximum flow rate @ outlet 1000 US GPM.
I can not find any reference regarding this matter, all I can found is for tanks storing flammable fluids. Also in case of concrete tanks, will the breathing in & out of tank can really cause failure to structure?
Amr Salah
Plumbing & Fire Protection Engineer
RE: Potable Water Storage Tank Vent Sizing
I need to submit calculation for this matter so I can not just put a larger pipe (although it would be sufficient). I need data to support my choice.
Amr Salah
Then just put ones in the same size or bigger than the water outlet pipe....
If you know the flow rate and need calculations for the vent, simplest solution is to use a commercially available "free vent" with flow data available. Varec has their flow data online, some of the others don't. Note that sizing a vent this way can give you a very small vent.
You can use duct-flow information from ASHRAE to estimate vent flow rates. They have data for screens, for exhaust hoods, for ells, etc., it's just a matter of hunting the information up and working out the details.
