ASME B31.1 Min Wall Calculation
I'm trying to perform the min wall calculation on parts that contain male NPT and female NPT threads. What diameter do you use for the calculations? For female NPT thread, I've been using the E3 diameter + thread height. For the male NPT threads, I've been using the E2 diameter + thread height. Is this correct? My assumption was that I should use the diameter after make-up of the threads since that is what would be exposed and not reinforced.
Jason
Jason
RE: ASME B31.1 Min Wall Calculation
