try to write code to loop through tolerance on drawing,but got some trouble
i try to loop through external CSV file so that the tolerance of each dimension on drawing can be updated.
the code is shown at the end;
the main idea is i give each dimension an appendedtext and it matches with the name in the CSV file, if matched, proceed to change tolerance
there are two big issues i encountered
the first one is at the beginning of the For each loop, i write
lw.WriteLine(dwgDimension.GetAppendedText.ToString)
in order to confirm NX can grab appendedtext. However, NX return all number, like 9898940694....
the second is after i run the code, NX gave me warning:
toleranceType is not declared. it may be inaccessible due to its protection level
what's my problem?
thank you
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
For Each sheet As Drawings.DrawingSheet In workPart.DrawingSheets
Dim partDimension() As Annotations.Dimension
partDimension = workPart.Dimensions.ToArray
Dim xlsData() As String
Using xlsFile As New Microsoft.VisualBasic.FileIO.TextFieldParser("E:\toleranceTest.csv")
xlsFile.SetDelimiters(",")
xlsFile.TextFieldType = FileIO.FieldType.Delimited
xlsFile.HasFieldsEnclosedInQuotes = True
While Not xlsFile.EndOfData
xlsData = xlsFile.ReadFields()
For Each dwgDimension As Annotations.Dimension In partDimension
If dwgDimension.GetAppendedText.ToString = xlsData(0) Then
If (Double.Parse(xlsData(2)) And Double.Parse(xlsData(3)) = 0) Then
dwgDimension.ToleranceType = ToleranceType.None
ElseIf (Double.Parse(xlsData(2)) <> 0 Or Double.Parse(xlsData(3) <> 0)) Then
If (Double.Parse(xlsData(2)) + Double.Parse(xlsData(3)) = 0) Then
dwgDimension.ToleranceType = ToleranceType.BilateralOneLine
dwgDimension.UpperMetricToleranceValue = Double.Parse(xlsData(2))
dwgDimension.LowerMetricToleranceValue = Double.Parse(xlsData(2))
Else
dwgDimension.ToleranceType = ToleranceType.BilateralTwoLines
dwgDimension.LowerMetricToleranceValue = Double.Parse(xlsData(3))
End If
End If
End If
Next
End While
End Using
Next
what's my problem?
thank you
Module Module1
Sub Main()
lw.Open()
Else
End If
End If
End If
Next
End While
End Using
Next
RE: try to write code to loop through tolerance on drawing,but got some trouble
For the tolerance type error, try importing NXOpen.Annotations
OR
change the references to the tolerance type enumeration from (for example)
to
= Annotations.ToleranceType.None
www.nxjournaling.com
thank you very much!
looping through tolerance succeeded!!!!!!!!
one step forward toward drawing automation process
