cascade versus multistage
good morning!
could you please simply explain the difference between a cascade system, and a multi-stage refrigeration system?
if i were to see a schematic of the two systems, what feature would tell me clearly whether this was cascade or multi-stage?
in a cascade system, is there a consideration between a lower and a higher BP fluid, as to which side of the common exchanger would each be?
why is a flash chamber considered more efficient than an intercooler?
i tried this question in the general section but did not get an answer
thank you very much
aamir raza
RE: cascade versus multistage
Cascade system is series cooling, multi-stage is parallel cooling.
willard3 i apologize for showing this as correct after your response i looked at the diagrams in a paper, and found that there are other aspects which have a role
regards
aamir
