How to specify parameters in command line in UG NX
Hi
I have a Macro but it says to input certain parameters in command line before executing can you please advise me on this
Rajesh
Rajesh
RE: How to specify parameters in command line in UG NX
* The modules are placed into UGSAMPLES.
* In order to execute this program, input the following parameters
* on the command line as described below.
* 1. part name: Full path name or the part name.
* 2. drawing name: The drawing which we want to plot. The drawing belongs to the part.
* 3. plot name
* for the drawing: Will be created in the directory specified by the environment
* variable PLOT_HPGL_OUTPUT_DIR using the name provided with an
* extension of .hpp.
* 4. log file name: File which contains error messages and comparison results.
* Will be created in the directory specified using the name provided.
* The printer and profile for the plot are given by the #define statements below. These
* need to correspond to a printer / profile pair set up to create HPGL output. See the
* sample program, ufd_plot_drawings_hpgl.c, for details on how to do this.
* The following is an example:
* cmp_dwg_create.platform part.prt SH1 part_sh1 log_file.txt
* The platform can be hpp, osf or sol. The source code provided for this example
* may be used to produce an executable on other platforms as well.
#include <ctype.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <uf.h>
#include <uf_defs.h>
#include <uf_obj.h>
#include <uf_part.h>
#include <uf_draw.h>
#include <uf_plot.h>
/* Type Defines */
#define CMP_DWG_CREATE__NO_ERRORS (0)
#define CMP_DWG_CREATE__BAD_PART_FILE (1)
#define CMP_DWG_CREATE__BAD_SHEET_NAME (2)
#define CMP_DWG_CREATE__BAD_PLOT_NAME (3)
#define CMP_DWG_CREATE__BAD_PRINTER (4)
#define CMP_DWG_CREATE__BAD_PROFILE (5)
#define CMP_DWG_CREATE__BAD_LOG_FILE (6)
#define CMP_DWG_CREATE__BAD_PLOT_DIR (7)
#define CMP_DWG_CREATE__BAD_DRAWINGS (8)
#define CMP_DWG_CREATE__BAD_LOAD (9)
#define NUM_EXPECTED_ARG ( 7 )
#define CMP_DWG_CREATE__MAX_WAIT (60)
#define CMP_DWG_CREATE__SLEEP_TIME (5)
typedef struct CMP_DWG_CREATE__line_data_s
char part_file[UF_CFI_MAX_PATH_NAME_LEN+1];
char sheet_name[UF_CFI_MAX_FILE_NAME_LEN+1];
char plot_name[UF_CFI_MAX_FILE_NAME_LEN+1];
char printer[UF_CFI_MAX_FILE_NAME_LEN+1];
char profile[UF_CFI_MAX_FILE_NAME_LEN+1];
char log_file[UF_CFI_MAX_FILE_NAME_LEN+1];
FILE *log_file_p;
} CMP_DWG_CREATE__line_data_t, *CMP_DWG_CREATE__line_data_p_t;
typedef struct CMP_DWG_CREATE__env_data_s
char plot_out_dir[UF_CFI_MAX_PATH_NAME_LEN+1];
} CMP_DWG_CREATE__env_data_t, *CMP_DWG_CREATE__env_data_p_t;
static void process_drawing(
CMP_DWG_CREATE__line_data_p_t line_data,
const tag_t drawing_sheet );
static void print_help( char *command );
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
/* #define UF_CALL(uf_func) ( print_fail_message( #uf_func, __FILE__, __LINE__, (uf_func))) */
#define PRINT_ERROR(args) {printf("ERROR: "); printf args; printf("\n");}
static int report_error( char *file, int line, char *call, int irc)
if (irc)
char err[133],
msg[133];
sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
irc, line, file);
UF_get_fail_message(irc, err);
UF_print_syslog(msg, FALSE);
UF_print_syslog(err, FALSE);
UF_print_syslog("\n", FALSE);
UF_print_syslog(call, FALSE);
UF_print_syslog(";\n", FALSE);
return(irc);
static void sleep_wait(
int time
clock_t time_to_wait = time * CLOCKS_PER_SEC;
clock_t start_time = clock();
clock_t cur_time = 0;
while (cur_time < time_to_wait)
cur_time = clock() - start_time;
static logical check_file_availability(
char *file_name,
logical wait
logical status = FALSE;
int total_wait = 0;
logical file_found = FALSE;
while( (total_wait <= CMP_DWG_CREATE__MAX_WAIT) && (file_found == FALSE) )
int file_exists = 0;
UF_CFI_ask_file_exist(file_name, &file_exists);
if ( file_exists == 0 )
file_found = TRUE;
else
if (wait)
sleep_wait( CMP_DWG_CREATE__SLEEP_TIME );
total_wait = total_wait + CMP_DWG_CREATE__SLEEP_TIME;
else
total_wait = CMP_DWG_CREATE__MAX_WAIT + 1;
if (file_found)
status = TRUE;
return( status );
static logical check_hpgl_printer(
const char *check_printer
logical result = false;
int i, num;
char **printers;
UF_CALL( UF_PLOT_ask_printer_names( &num, &printers ) );
for ( i=0; i < num; i++ )
if ( strcmp( printers[i], check_printer ) == 0 )
result = true;
break;
UF_free( printers );
return result;
static logical check_hpgl_profile(
char *check_printer,
const char *check_profile
int i, num;
char **profiles;
UF_CALL( UF_PLOT_ask_profile_names( check_printer, &num, &profiles ) );
if ( strcmp( profiles[i], check_profile ) == 0 )
result = true;
break;
UF_free( profiles );
return result;
static int query_line_data(
int argc,
char *argv[],
/* Initialize ARG module for UGManager */
UF_CALL(uc4624(0, argc, argv));
if (argc != NUM_EXPECTED_ARG)
printf( "ERROR: Invalid number of command line arguments.\n" );
print_help(argv[0]);
return(1);
/* Get part_file option */
if ((uc4621(line_data->part_file) != 1) ||
(!check_file_availability(line_data->part_file, false)))
PRINT_ERROR(( "Part file does not exist.\n"));
return(CMP_DWG_CREATE__BAD_PART_FILE);
/* Get sheet_name option */
if (uc4621(line_data->sheet_name) != 1)
PRINT_ERROR(( "Sheet name not specified.\n"));
return(CMP_DWG_CREATE__BAD_SHEET_NAME);
/* Get plot_name option */
if (uc4621(line_data->plot_name) != 1)
PRINT_ERROR(( "Plot name not specified.\n"));
return(CMP_DWG_CREATE__BAD_PLOT_NAME);
/* Get printer option */
if (uc4621(line_data->printer) != 1)
PRINT_ERROR(( "Printer is not specified.\n"));
return(CMP_DWG_CREATE__BAD_PRINTER);
else if ( !check_hpgl_printer(line_data->printer) )
PRINT_ERROR(( "Printer named %s is not defined.\n", line_data->printer ));
/* Get profile option */
if (uc4621(line_data->profile) != 1)
PRINT_ERROR(( "Profile is not specified.\n"));
return(CMP_DWG_CREATE__BAD_PROFILE);
else if ( !check_hpgl_profile(line_data->printer, line_data->profile) )
PRINT_ERROR(( "Profile named %s is not defined.\n", line_data->profile ));
/* Get log_file option */
if (uc4621(line_data->log_file) != 1)
PRINT_ERROR(( "Unable to open log file.\n"));
return(CMP_DWG_CREATE__BAD_LOG_FILE);
else
line_data->log_file_p = fopen( line_data->log_file, "w");
if (line_data->log_file_p == NULL)
return(CMP_DWG_CREATE__NO_ERRORS);
static int query_env_data(
CMP_DWG_CREATE__env_data_p_t env_data
int return_code = CMP_DWG_CREATE__NO_ERRORS;
char *plot_path_string = NULL;
UF_translate_variable("PLOT_HPGL_OUTPUT_DIR", &plot_path_string);
if (plot_path_string != NULL)
/* Ensure that the given path is a valid directory */
return_code = UF_CFI_ask_file_exist(plot_path_string, &file_exists);
if (return_code != CMP_DWG_CREATE__NO_ERRORS || file_exists != 0)
PRINT_ERROR(("The plot path specified does not exist.\n"));
PRINT_ERROR(("Please set PLOT_HPGL_OUTPUT_DIR variable.\n"));
if (return_code == CMP_DWG_CREATE__NO_ERRORS)
strcpy(env_data->plot_out_dir, plot_path_string);
else
PRINT_ERROR(("No plot path specified.\n"));
return_code = CMP_DWG_CREATE__BAD_PLOT_DIR;
return (return_code);
int main( int argc, char *argv[] )
CMP_DWG_CREATE__line_data_t line_data;
CMP_DWG_CREATE__env_data_t env_data;
char error_message[MAX_LINE_SIZE+1];
int ifail = 0;
int inx;
tag_t part_tag = NULL_TAG; /* for UF_PART_open */
memset( &line_data, 0, sizeof(CMP_DWG_CREATE__line_data_t) );
/* Initialize */
if ( (return_code = UF_CALL(UF_initialize())) != CMP_DWG_CREATE__NO_ERRORS)
PRINT_ERROR(( "UG could not be initialized properly. \n"));
return( return_code );
return_code = query_line_data(argc, argv, &line_data);
return_code = query_env_data(&env_data);
if ( return_code == CMP_DWG_CREATE__NO_ERRORS )
UF_PART_load_status_t err_status; /* for UF_PART_open */
ifail = UF_PART_open( line_data.part_file, &part_tag, &err_status );
if ( err_status.n_parts != 0 )
for ( inx=0; inx<err_status.n_parts; ++inx)
UF_free( err_status.statuses );
UF_free_string_array( err_status.n_parts, err_status.file_names );
/* When a part is not opened because it doesn't exist, the part_tag remains
* equal to NULL_TAG, and no actual error is returned.
* We therefore choose to write our own error message to the log_file here.
if ( part_tag == NULL_TAG )
fprintf( line_data.log_file_p, "ERROR: Failed to retrieve part %s \n", line_data.part_file );
ifail = -1;
if ( ifail == 0 )
int num = 0;
tag_t *drawings = NULL;
tag_t drawing_sheet;
char drawing_name[UF_OBJ_NAME_LEN+1];
UF_CALL( UF_DRAW_ask_drawings( &num, &drawings ) );
drawing_sheet = NULL_TAG;
for ( inx=0 ; inx < num ; inx++ )
UF_CALL( UF_OBJ_ask_name( drawings[inx], drawing_name ) );
if ( strcmp( drawing_name, line_data.sheet_name ) == 0 )
drawing_sheet = drawings[inx];
break;
UF_free(drawings);
if ( drawing_sheet == NULL_TAG )
fprintf( line_data.log_file_p, "Part %s does not have a drawing named %s\n",
line_data.part_file, line_data.sheet_name );
ifail = -1;
else
int scope = 1; /* Close part and all sub-assemblies */
int mode = 1; /* Unload part even if modified */
process_drawing( &line_data, drawing_sheet );
ifail = UF_PART_close( part_tag, scope, mode );
if ( (ifail != 0) && (ifail != -1) )
ifail = UF_get_fail_message( ifail, error_message );
fprintf( line_data.log_file_p, "ERROR: %s \n\n", error_message );
UF_terminate();
fclose( line_data.log_file_p );
return(0);
We need a full file spec for the name of the CGM to pass to the print
routine.
static char * get_cgm_name( const char *plot_name )
char *cgm_name;
char dir_name[UF_CFI_MAX_PATH_NAME_SIZE];
char *ext_loc;
char cgm_ext[] = ".cgm";
uc4565( 1, dir_name );
cgm_name = (char *) malloc( UF_CFI_MAX_PATH_NAME_SIZE * sizeof(char) );
if( cgm_name != NULL )
uc4575( dir_name, 2, plot_name, cgm_name );
ext_loc = strrchr( cgm_name, '.' );
if ( ext_loc )
*ext_loc = '\0';
strcat( cgm_name, cgm_ext );
return cgm_name;
char *job_name;
char *cgm_name;
cgm_name = get_cgm_name( line_data->plot_name );
UF_CALL( UF_PLOT_ask_default_job_name( drawing_sheet, &job_name ) );
UF_CALL( UF_PLOT_save_cgm( drawing_sheet, NULL, job_name,
NULL, cgm_name ) );
/* NOTE that cgm_name must be a full file spec. */
UF_CALL( UF_PLOT_print_file( cgm_name, line_data->printer,
line_data->profile, 1 ) );
uc4561( cgm_name, 0 );
UF_free( job_name );
free( cgm_name );
char *command
printf( "%s <part_name> <drawing_name> <plot_name> <printer> <profile> <log_file>\n", command );
printf( " <part_name> Full path and name of drawing part.\n" );
printf( " <drawing_name> Name of drawing sheet in part.\n" );
printf( " <plot_name> Name of .hpp file to be created.\n" );
printf( " <printer> Name of printer to use.\n" );
printf( " <profile> Name of printer profile to use.\n" );
printf( " <log_file> Full path and name of output log file.\n");
printf( "\n");
printf( "The following environmental variables should also be set: \n" );
printf( " PLOT_HPGL_OUTPUT_DIR Output directory of plotter.\n");
printf( "\n\n" );
How to input those parameters.....
