Need help finding which direction to take.
Hello again all,
I am tasked with reverse engineering control arms for utvs. What I basically need to do is reverse engineer the arms, draw them in SW, and then create flat pattern dxfs, I will be making these in sheet metal. Here is a example picture of a stock arm that would be reverse engineered.
So these tube arms will be basically boxed sheet metal, like a 3D puzzle.
What I am curious about is the best way to go about this, I was looking at the weldment function, but I'm not sure that will work out. So I think just making a 3D drawing into a assembly. And then I need to make each piece, which will be bent in the assembly into a flat piece. If that makes sense.
Any other Ideas?
Thank you.
RE: Need help finding which direction to take.
Have you tried the weldment function? That is how I would do it.
You can create each tube solid and convert to sheetmetal, then make the assy.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
Wow, thank you Ctopher. This is perfect, I will play around with this and try and get it to work!
