solid edge visible line display
I've got ST4 on 32 bit win7, and in the normal model window I've got some edge lines that show through an assembly when they shouldn't.
Here's an example of what i'm talking about:
Link
For awhile I thought it had something to do with the VHL overlay, but as you can see in the pictures, the errant lines remain even with VHL overlay disabled. I do have some pretty thin parts in this assembly, perhaps that is the problem.
Link
RE: solid edge visible line display
Hopefully this should work.
The major use is to make a sketch from a part visible so that it can be used to create assembly level features with reference to other parts in the assembly, that cannot be made in the part alone.
