API 653 What to do When Tank Exceeds Out of Plumb
Hi folks. What are you to do when a tank exceeds the Out of Plumb measurement per API 653of 5"??? This is a 70 ft diameter x 40 ft high tank, leaning 20" on a clay soil. HELP!!!
Is there a requirement to relevel?
RE: API 653 What to do When Tank Exceeds Out of Plumb
Refer to API-653-4.1, "an evaluation shall be made to determine its suitability for continued use".
See Annex B for more information on settlement and evaluation of settlement.
Are all the manholes submerged?
It would be great to see a photo of this as 4 1/2 feet just sounds unreal....
If it contains anything hazardous or flammable then it definitely needs re-building IMO, but otherwise?? Tank would probably be showing signs of distress if it was in a really bad way so it might have some life left in it, but a properly supported raft foundation sounds like a good plan next time.
Refill with the S.G 1.5 material and measure further settlement, and use that measurement to compensate on the second tank being mud jacked. Rinse & repeat.
