Welding callout question
I have a small plate that is currently being welded onto a sheet metal part to act as a recessed face for a control panel to sit so it is flush with the sheet metal part. The part is called out to use a spot weld on the drawing, but a tack weld could be used as well and it would not effect FFF...How would you call out that weld to show either option, or would you make it a drawing note?
~Boottmills
RE: Welding callout question
Tack weld isn't a specific type of weld - it refers to temporary partial welds to hold pieces in place for fully welding.
AWS 2.4 is probably your friend assuming US based.
Extracts/summaries are available for free online.
In terms of giving options, I think probably a note.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
