Process engineer
Process engineer
I a new in process engineering, and I need a tips in this topic
My question is:
I need to find out the volume of cooling unit shown in the attached figure; I just wonder where I can find the equations to calculate the volume of the cooling unit (diameter of the unit).
Tanks in advantage
My question is:
Tanks in advantage
RE: Process engineer
Future PE Engineer
Pet project I am working on to help other engineers, not much yet hoping to get it grow as I learn more
http://www.peexamquestions.com
StoneCold
I will explain the problem more clearly
This is a unit for cooling (condensation). The purpose is to cool 715 kg/h of vapor to 30 degree by means of direct contact with seawater in a spray tower (see-attached sketch). The seawater temperature is 12 degree. Vapor properties are given as following:
Mass flow = 715 kg/h
Steam temperature = 121 degree
Steam pressure = 1.028 bar
Molar enthalpy = -24230 kJ/Kgmole
Mass density = 0.6141 kg/m^3
The steam /vapor inlet pipe = 8’’
The unit shall not exceed the following dimensions: 1.5x1.5x2.5 m (Length x width x height)
What I looking for here is to find the diameter D, D1 and D2 (see attachment).
Tank you in advantage
I tried but its vast subject
Anyway can you send to me where can I find informations this/these subjects
