small parts with reaction injection molding (RIM)
Can very small parts be made with reaction injection molding?
For example, very small gears (5mm in diameter).
What about small enclosures the size to a cigarette box?
They have to be fairly precise (dimensionally stable) in order to preserve snap fitting.
I may need to manufacture a large variety of parts (but with low volumes for each part) injection molding may not be cost effective and manually casting may be too slow.
Will low pressure or high pressure RIM be best?
Thanks.
Thanks.
RE: small parts with reaction injection molding (RIM)
Tiny parts like that would be producible in a small mold made of steel or maybe aluminum. I don't ordinarily recommend 'insert molds', but they might be appropriate for your variety.
I used to partner with a guy who did low volume stuff for reasonable prices with small simple molds and precise choreography, but he's not available anymore.
I suggest limiting yourself to nylon or acetal.
Mike Halloran
Pembroke Pines, FL, USA
www.stratasys.com and http://store.makerbot.com/
Dr. Chris DeArmitt
Plastics consultant to the Fortune 500: www.phantomplastics.com
Webinars on plastics, fillers & impact modification: www.plastictraining.com
