Kinematic trace
Kinematic trace
hi,
When you rotate the tyre about the king pin axis how do you get the elliptical path ? I don’t get it right. Could you please explain this?
Because whenever you revolve or rotate anything about an axis, we get a circle. So is there any other parameter that is controlling the movement of tyre ?
RE: Kinematic trace
RE: Kinematic trace
I am asking about the motion of tyre motion in actual case.
RE: Kinematic trace
