cure EPDM profiles in hot air tunnel.
It's highly appreciate to somebody tell me, how can I cure EPDM profiles in hot air tunnel?
cure EPDM profiles in hot air tunnel.cure EPDM profiles in hot air tunnel.(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: cure EPDM profiles in hot air tunnel.
What throughput rate, and what space/time/budget do you have?
What temperature and flow rate of air is available, or do you need to heat that air as well?
You have asked the equivalent of: "I have a building. What will it cost to paint it?"
Thanks a lot for your kind attention,The temperature is 300C and the curing time is 1minute,and the tunnel length is 12meters, material out put is 450grs per minute.hope the information would be useful.
I would appreciate both of you for your kind attentions,I mentioned the technical information,and also I will try to find the EPDM rubber chemical component supplier but still looking for to know totally is it possible to cure EPDM in hot air tunnel?,then if yes how can I design my compounding formulation?.
I'm no expert in this field, but I think 300°C is high for hot air oven curing of EPDM; more typical may be ~3-4 minutes at 200°-210°C. A fast curing compound with a good amount of calcium oxide would be needed.
Good luck!
