Soldier Pile and Lagging Design Software with LRFD
We just got released on a large pile and lagging wall. We have MathCad sheets tooled for ASD design methods, however this project needs to be LRFD. Does anybody know if any design software has been retooled for LRFD, if so, which ones are the good ones? I see RetainPro 10 has a option for it, but honestly, I don't trust a program that claims to be that versatile for a couple hundred bucks.
RE: Soldier Pile and Lagging Design Software with LRFD
www.PeirceEngineering.com
Soil load x 1.5 and live load x 1.75 is the load side. The resistance side will have shear or bending factor increased from 0.50/0.60 to 0.80/0.90 or something like that to compensate for the higher factored loads. The CDR is the factored resistance / factored loads > 1.0
In a spreadsheet, it is just a bunch if IF statements that provide a CDR vs. FS or whatever the working stress works out to be. All the same equations are used so not a lot of new programming is required.
The Strength Limit State for a retaining wall is usually Strength I which are maximum load factors for earth pressure, dead and live loads. The Service Limit State is usually Service I where the load factors are set = 1.0 for "realistic" loads and settlement/deflections can be calculated. Retaining wall design typically does not have to concern itself with wind, ice, thermal, etc loads which makes it a lot simpler than bridges.
The Extreme Limits states are typically for seismic analysis and collision type loads which do not occur on a regular basis.
That lines up with everything I have researched and clarifies things quite a bit for me. I appreciate your help in this matter.
http://www.soilstructure.com/
