Removing Existing Variables in Abaqus Python Script
I realized that ABAQUS python compiler (I dont know if this is the correct term) writes the new variable over existing ones. It does not remove all variable and redefine them. So my question: which command should i use the clear the existing variables before running the new script e.g., clear all in matlab?
RE: Removing Existing Variables in Abaqus Python Script
set them at 0 in the beginning of the script.
Thanks for suggestion but it is not a practical solution since there are a lot of variable.
i just remembered: use a function. variables are only accessible within that function and are cleared when you exit that function (except the return of the function if there is any)
