Solidworks 2013 export to dwg
Does anyone know when SolidWorks exports out to dwg how it creates the dwg file? Not the map file but what template it uses. What I want to do is set it up to use the same dwg template so i don't have to be modifying dimstyle's etc.
RE: Solidworks 2013 export to dwg
Check for mapping option while export/saving as DWG/DXF. Ckick on option when you set the save as type to DXF/DWG and then go to mapping.
Deepak Gupta
CSWE, CSWP, CSDA
SW 2012 SP5.0 & 2013 SP 3.0
Boxer's SolidWorks™ Blog
SolidWorks™ Rendering Contest
