RCD protection
RCD protection
Am I correct in thinking that if a rcd feeds a transformer, then anything connected to the secondary of the transformer will not be protected by the rcd and another rcd is required to provide protection
RE: RCD protection
But only if it is an autotransformer (no isolation between primary and secondary).
Gunnar Englund
www.gke.org
RE: RCD protection
An rcd on the primary of a normal transformer ie two electrically isolated coils would not provide protection to the circuits on the secondary
is that correct
RE: RCD protection
Gunnar Englund
www.gke.org
RE: RCD protection
Did you mean to say "Unless" rather than "But only if" ??
On the other hand I'm still on my first cup of coffee this morning.
Bill
"Why not the best?"
Jimmy Carter
RE: RCD protection
Of course it should be "unless". I think that richerdick got it. And that was NOT exactly what I said.
Gunnar Englund
www.gke.org
