Contact Force on certain locations in ADAMS
Hi
I have a question about measuring contact forces in ADAMS
Imagine we have box falling on a plate. When I measure the contact force (clicking on Measure for Contact) it gives me one value for contact force (say Fy for example) what if I want to find out the contact force on a certain location on the box during impact?
I have tried putting markers there and measuring Force on point but the value remains 0 during whole process.
Here is a picture to clarify my question
http://s28.postimg.org/rvyanax8t/question.jpg
[/url]]
[/url]]
RE: Contact Force on certain locations in ADAMS
your contact force statement measures the force in the constraint. since there is no constraint at your new marker position, there is no force to measure.
Cheers
Greg Locock
In that case the amount of force that has been measured here is exactly at which constraint? Is it at the revolving joints? or on the whole contact area?
Cheers
Greg Locock
I will attach it tomorrow morning. (I just have access to Adams at school)
Thanks in advance
!-------------------------- Default Units for Model ---------------------------!
defaults units &
length = meter &
angle = deg &
force = newton &
mass = kg &
time = sec
defaults units &
coordinate_system_type = cartesian &
orientation_type = body313
!------------------------ Default Attributes for Model ------------------------!
defaults attributes &
inheritance = bottom_up &
icon_visibility = on &
grid_visibility = off &
size_of_icons = 5.0E-002 &
spacing_for_grid = 1.0
!------------------------------ Adams/View Model ------------------------------!
model create &
model_name = ramp
view erase
!--------------------------------- Materials ----------------------------------!
material create &
material_name = .ramp.steel &
adams_id = 1 &
youngs_modulus = 2.07E+011 &
poissons_ratio = 0.29 &
density = 7801.0
!-------------------------------- Rigid Parts ---------------------------------!
! Create parts and their dependent markers and graphics
!----------------------------------- ground -----------------------------------!
! ****** Ground Part ******
defaults model &
part_name = ground
defaults coordinate_system &
default_coordinate_system = .ramp.ground
! ****** Markers for current part ******
marker create &
marker_name = .ramp.ground.MARKER_1 &
adams_id = 1 &
location = 0.0, 0.0, 0.0 &
orientation = 45.0d, 0.0d, 0.0d
marker create &
marker_name = .ramp.ground.MARKER_7 &
adams_id = 7 &
location = -3.5355339059E-002, 3.5355339059E-002, 1.38 &
orientation = 0.0d, 0.0d, 0.0d
marker create &
marker_name = .ramp.ground.MARKER_9 &
adams_id = 9 &
location = -3.5355339059E-002, 3.5355339059E-002, 0.0 &
marker create &
marker_name = .ramp.ground.MARKER_11 &
adams_id = 11 &
location = -0.4, -5.0E-002, 0.0 &
marker create &
marker_name = .ramp.ground.MARKER_13 &
adams_id = 13 &
location = -0.4, -5.0E-002, 1.38 &
marker create &
marker_name = .ramp.ground.MARKER_15 &
adams_id = 15 &
location = 0.0, -5.0E-002, 1.38 &
marker create &
marker_name = .ramp.ground.MARKER_17 &
adams_id = 17 &
location = 0.0, -5.0E-002, 0.0 &
! ****** Graphics for current part ******
geometry create shape block &
block_name = .ramp.ground.BOX_1 &
adams_id = 1 &
corner_marker = .ramp.ground.MARKER_1 &
diag_corner_coords = 0.259, 5.0E-002, 1.38
!----------------------------------- PART_2 -----------------------------------!
part create rigid_body name_and_position &
part_name = .ramp.PART_2 &
adams_id = 2 &
default_coordinate_system = .ramp.PART_2
marker create &
marker_name = .ramp.PART_2.MARKER_2 &
adams_id = 2 &
marker create &
marker_name = .ramp.PART_2.cm &
adams_id = 18 &
location = -0.2, -2.5E-002, 0.69 &
orientation = 90.0d, 180.0d, 0.0d
marker create &
marker_name = .ramp.PART_2.MARKER_10 &
adams_id = 10 &
marker create &
marker_name = .ramp.PART_2.MARKER_12 &
adams_id = 12 &
marker create &
marker_name = .ramp.PART_2.MARKER_14 &
adams_id = 14 &
marker create &
marker_name = .ramp.PART_2.MARKER_16 &
adams_id = 16 &
marker create &
marker_name = .ramp.PART_2.MARKER_20 &
adams_id = 20 &
location = -0.4, 0.0, 0.0 &
part create rigid_body mass_properties &
material_type = .ramp.steel
block_name = .ramp.PART_2.BOX_2 &
adams_id = 2 &
corner_marker = .ramp.PART_2.MARKER_2 &
diag_corner_coords = 0.4, 5.0E-002, 1.38
part attributes &
color = CYAN &
name_visibility = off
!----------------------------------- PART_3 -----------------------------------!
part_name = .ramp.PART_3 &
adams_id = 3 &
default_coordinate_system = .ramp.PART_3
marker create &
marker_name = .ramp.PART_3.MARKER_3 &
adams_id = 3 &
location = 0.0, 5.0E-002, 0.0 &
marker create &
marker_name = .ramp.PART_3.cm &
adams_id = 19 &
location = 0.1295, 0.229, 0.69 &
marker create &
marker_name = .ramp.PART_3.MARKER_4 &
adams_id = 4 &
location = 0.0, 0.408, 1.38 &
marker create &
marker_name = .ramp.PART_3.CG &
adams_id = 5 &
location = 0.1410678028, 0.2124855877, 0.69 &
marker create &
marker_name = .ramp.PART_3.MARKER_6 &
adams_id = 6 &
location = 0.0, 5.0E-002, 1.38 &
orientation = 315.0d, 0.0d, 0.0d
marker create &
marker_name = .ramp.PART_3.MARKER_8 &
adams_id = 8 &
marker create &
marker_name = .ramp.PART_3.MARKER_21 &
adams_id = 21 &
location = 0.0, 0.408, 0.0 &
mass = 998.18756436 &
center_of_mass_marker = .ramp.PART_3.CG &
ixx = 169.0733423805 &
iyy = 163.992318131 &
izz = 16.2409275836 &
ixy = 0.0 &
izx = 0.0 &
iyz = 0.0
block_name = .ramp.PART_3.BOX_3 &
adams_id = 3 &
corner_marker = .ramp.PART_3.MARKER_3 &
diag_corner_coords = 0.259, 0.358, 1.38
part attributes &
color = MAGENTA &
!---------------------------------- Contacts ----------------------------------!
contact create &
contact_name = .ramp.CONTACT_1 &
adams_id = 1 &
i_geometry_name = .ramp.PART_3.BOX_3 &
j_geometry_name = .ramp.ground.BOX_1 &
stiffness = 1.0E+008 &
damping = 1.0E+004 &
exponent = 2.2 &
dmax = 1.0E-004
contact create &
contact_name = .ramp.CONTACT_2 &
adams_id = 2 &
j_geometry_name = .ramp.PART_2.BOX_2 &
stiffness = 1.0E+009 &
exponent = 2.2 &
dmax = 1.0E-003
!----------------------------------- Joints -----------------------------------!
constraint create joint revolute &
joint_name = .ramp.JOINT_1 &
adams_id = 1 &
i_marker_name = .ramp.PART_3.MARKER_6 &
j_marker_name = .ramp.ground.MARKER_7
constraint attributes &
constraint_name = .ramp.JOINT_1 &
joint_name = .ramp.JOINT_2 &
adams_id = 2 &
i_marker_name = .ramp.PART_3.MARKER_8 &
j_marker_name = .ramp.ground.MARKER_9
constraint_name = .ramp.JOINT_2 &
constraint create joint fixed &
joint_name = .ramp.JOINT_3 &
adams_id = 3 &
i_marker_name = .ramp.PART_2.MARKER_10 &
j_marker_name = .ramp.ground.MARKER_11
constraint_name = .ramp.JOINT_3 &
joint_name = .ramp.JOINT_4 &
adams_id = 4 &
i_marker_name = .ramp.PART_2.MARKER_12 &
j_marker_name = .ramp.ground.MARKER_13
constraint_name = .ramp.JOINT_4 &
joint_name = .ramp.JOINT_5 &
adams_id = 5 &
i_marker_name = .ramp.PART_2.MARKER_14 &
j_marker_name = .ramp.ground.MARKER_15
constraint_name = .ramp.JOINT_5 &
joint_name = .ramp.JOINT_6 &
adams_id = 6 &
i_marker_name = .ramp.PART_2.MARKER_16 &
j_marker_name = .ramp.ground.MARKER_17
constraint_name = .ramp.JOINT_6 &
!----------------------------------- Forces -----------------------------------!
!----------------------------- Simulation Scripts -----------------------------!
simulation script create &
sim_script_name = .ramp.Last_Sim &
commands = &
"simulation single_run transient type=auto_select initial_static=no end_time=0.7 number_of_steps=200 model_name=.ramp"
!------------------------------ Dynamic Graphics ------------------------------!
geometry create shape gcontact &
contact_force_name = .ramp.GCONTACT_6 &
adams_id = 6 &
contact_element_name = .ramp.CONTACT_1 &
force_display = components
geometry attributes &
geometry_name = .ramp.GCONTACT_6 &
color = RED
contact_force_name = .ramp.GCONTACT_9 &
adams_id = 9 &
contact_element_name = .ramp.CONTACT_2 &
geometry_name = .ramp.GCONTACT_9 &
color = RED
!---------------------------------- Accgrav -----------------------------------!
force create body gravitational &
gravity_field_name = GRAVITY &
x_component_gravity = 0.0 &
y_component_gravity = -9.80665 &
z_component_gravity = 0.0
!----------------------------- Analysis settings ------------------------------!
!---------------------------------- Measures ----------------------------------!
measure create object &
measure_name = .ramp.FY_contact &
from_first = yes &
object = .ramp.CONTACT_2 &
characteristic = element_force &
component = y_component
data_element attributes &
data_element_name = .ramp.FY_contact &
color = WHITE
measure_name = .ramp.FY_surf &
from_first = no &
component = y_component &
create_measure_display = no
data_element_name = .ramp.FY_surf &
color = WHITE
measure create point &
measure_name = .ramp.FY_Upper_edge_1 &
point = .ramp.PART_3.MARKER_4 &
characteristic = total_force_on_point &
data_element_name = .ramp.FY_Upper_edge_1 &
active = off &
color = WHITE
measure_name = .ramp.Fy_Upper_edge_2 &
data_element_name = .ramp.Fy_Upper_edge_2 &
active = off &
color = WHITE
measure_name = .ramp.MARKER_4_MEA_1 &
component = x_component &
data_element_name = .ramp.MARKER_4_MEA_1 &
active = off &
color = WHITE
measure_name = .ramp.MARKER_4_MEA_2 &
data_element_name = .ramp.MARKER_4_MEA_2 &
active = off &
color = WHITE
measure_name = .ramp.MARKER_4_MEA_3 &
component = mag_component &
data_element_name = .ramp.MARKER_4_MEA_3 &
active = off &
color = WHITE
measure_name = .ramp.MARKER_8_MEA_1 &
point = .ramp.PART_3.MARKER_8 &
characteristic = angular_acceleration &
data_element_name = .ramp.MARKER_8_MEA_1 &
color = WHITE
measure_name = .ramp.MARKER_8_MEA_2 &
data_element_name = .ramp.MARKER_8_MEA_2 &
color = WHITE
measure_name = .ramp.MARKER_4_MEA_4 &
data_element_name = .ramp.MARKER_4_MEA_4 &
active = off &
color = WHITE
measure_name = .ramp.MARKER_4_MEA_5 &
characteristic = translational_displacement &
data_element_name = .ramp.MARKER_4_MEA_5 &
color = WHITE
measure_name = .ramp.MARKER_20_MEA_1 &
point = .ramp.PART_2.MARKER_20 &
data_element_name = .ramp.MARKER_20_MEA_1 &
active = off &
color = WHITE
measure_name = .ramp.Force_On_point_Top_left_corner &
point = .ramp.PART_3.MARKER_21 &
data_element_name = .ramp.Force_On_point_Top_left_corner &
active = off &
color = WHITE
!---------------------------- Function definitions ----------------------------!
!--------------------------- Expression definitions ---------------------------!
default_coordinate_system = ground
geometry modify shape block &
diag_corner_coords = &
(25.9cm), &
(5cm), &
(138cm)
(40cm), &
(5cm), &
(138cm)
(25.9cm), &
(35.8cm), &
(138cm)
material modify &
youngs_modulus = (2.07E+011(Newton/meter**2)) &
density = (7801.0(kg/meter**3))
model display &
model_name = ramp
